RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA 50 mounting (https://www.rcuniverse.com/forum/gas-engines-142/4052942-da-50-mounting.html)
manofsteel 03-19-2006 08:42 AM
DA 50 mounting
What is the best way to mount the DA50 to TF giant scale p51? Should I use 3 1/2" mount extentions or make an engine box? What size prop should I use ? Thanks
Nogyro 03-19-2006 09:38 PM
RE: DA 50 mounting
I don't know about your engine box, but for a prop you can run a 22x10 Bolly wood and expect right at 7,000 rpm. A mejzlik 22x10 will turn up about 300 more r's. If that's not fast enough for you, maybe drop down to a 20x12. I got a hunch you'll be pleasantly surprised with the 22x10 though.:) Just prop the engine so it will be in the upper 6's to low 7's on rpm and the engine will be happy....
JoeAirPort 03-19-2006 10:51 PM
RE: DA 50 mounting
I was bored and did some searching for you (because I am not a warbird expert). This thread is pretty good.
http://www.rcuniverse.com/forum/m_39...tm.htm#3973308
