RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   bubbles in fuel lines (https://www.rcuniverse.com/forum/gas-engines-142/4053273-bubbles-fuel-lines.html)
moman133 03-19-2006 10:39 AM
What do i do to fix this problem? I have a p 51 with a 65 " wingspan with a saito 100 four stroke. I 'm aware that it is caused by vibrations, is there any quick fix to this problem?
tom
Zippi 03-19-2006 10:46 AM
RE: bubbles in fuel lines
See if you can take some pieces of foam and wedge it in next to your tank with a screw driver. You also might want to check your fuel lines for leaks.
ORIGINAL: moman133
tom
3dd 03-19-2006 10:56 AM
zippi has got ya covered ,zip tie your fuel lines
Tired Old Man 03-19-2006 11:16 AM
The most productive way of all. See if you can find a small gas filterat an auto supply or small engine shop that contains a paper filter element. Adapt your fuel lines to fit the larger ends on the filter and install it somewhere in the supply line. I don't know the reason why, but air bubbles don't seem to get past the filter.
