RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   spinner ? (https://www.rcuniverse.com/forum/gas-engines-142/4090699-spinner.html)
gottagofaster 03-27-2006 07:32 PM
spinner ?
need some advice.
I'm working on a conversion engine (25 cc sthil) w/ a 16x8 prop. I don't have any local resource to help me find the right size spinner. I assume that someone here would know.
Thanks in advance.
just for kicks there is a pic of the engine as it stands now.
http://img.photobucket.com/albums/v2...r/b59c21bf.jpg
stomper 03-28-2006 06:47 AM
RE: spinner ?
What plane?
You need to size your spinner to the plane you will be using.
gottagofaster 03-28-2006 08:04 AM
RE: spinner ?
this isn't going on a airplaine. it will be going on an airboat (swamp buggy)
dimentions of the boat are 40" long by 18" wide
will a 3 1/2" do or will i need to go bigger?
stomper 03-28-2006 08:09 AM
RE: spinner ?
Okay then 3 1/2" will be fine.
Bass1 03-28-2006 09:06 PM
RE: spinner ?
I'm using a 2 1/4" Tru- turn standard with a 18/6 Mejzlik on one of my planes. Works great. You have to dremel the prop slots to fit but no biggie. oops you said 16/8, It still would work. I'd go for the smallest I could get away with to save weight.
