RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   CH ignition Grounding (https://www.rcuniverse.com/forum/gas-engines-142/410033-ch-ignition-grounding.html)
VoughtF4U 12-10-2002 06:24 PM
I have a standard CH ignition on a FPE 3.2 engine. This weekend as I was taxiing out to take off, I noticed the grounding strap from the ignition wire was dangling below the engine. Engine still ran fine. I shut it down and brought it back to the pits. This is the ignition module with the seperate wire that is bolted to the engine, not the wire with the cap over the spark plug with a hose clamp type fitting.
I must have stripped out the threads for the bolt holding the grounding wire to the engine. Anyway, after bolting the ground strap to the engine mount I can no longer get the engine to fire. I remember reading somewhere that you can fry the ignition module if you turn the engine over if it wasn't grounded (I think that is what I read).
Can anyone confirm this? Or is my problem somewhere else? Does it sound like my ignition is fried? Should I order a new one or can this one be sent back to be fixed? Any suggestions?
w8ye 12-10-2002 11:05 PM
Did you check to see if you have sprk?
Antique 12-10-2002 11:14 PM
Running without the ground will not fry the ignition, only
the sensor..The ignition is normally grounded by the outside braid on the spark plug wire...If that didn't come off the ground was not lost.....C&H is good about fixing ignitions, unless it's a very old model.....
decartme 12-11-2002 04:40 AM
Hey I found this from C&H it is a test procedure for the ignition. May have just been a fluke that the ignition did not work after the ground wire came off. Check it out. This may help. :)
http://www.ch-ignitions.com/CHinst.html
F1race11 12-11-2002 03:27 PM
the sensor..
Or the SyncroSpark if you have one installed. Murphy says the most expensive part will fail!
