3W 75 Side induction Engine
does anybody have a 3W 75 side Induction engine? I'm thinking of putting one in my new Aeroworks Edge 540. Any comments about the Engine, or it's application to this plane are appreciated
John |
Awesome engine.
I have one on a 30% Carden Extra. Mucho power. Runs great and is not really broken in yet. http://www.aircraftinternational.com/ |
does it run smooth? are you using isolation mounts?
1 Attachment(s)
Very smooth, no isolation mounts.
isolation mounts are not really a great idea, sometimes they cause more problems. The photo is not the best but you can see the mounting method. |
Looks very nice! easy access to the throttle. How about the choke? do you have a picture of the other side?
thanks John |
1 Attachment(s)
You can see the lower portion of the home made choke lever in the photo.
It can be reached from the cutout for the muffler. |
3w-75
What are the prop and rpm numbers? Will it really turn a 26-10?
Engine Mount
Jemo,
what kind of engine mount is that? I am building a 30% Carden Cap and I also have a 3w-75us I will be running on it. Why did you stand the motor off as opposed to adjusting f-1? Do you also have the mounting plate Gerhard sells? I cannot tell from the picture. I like the choke idea. Thanks, Jess |
The engine mount is home made from 1/4" G-10 material, but it is really the same type as sold by AI.
I did adjust F!, but did not want to chance screwing up and going too far, so I used a compromise, and it worked out fine. I don't have any rpm numbers for you, but yes it will turn a 26 X 10 and the power is fantastic. I plan on (someday) using a 3 blade 22 X 12, I haven't tried it yet but a guy I know flies them on his 75 and likes it. |
Thanks for the info, what was your finished weight? Looks like you have smoke.
Jess |
The smoke, plumbing , tank & battery are installed, but did not get a pump yet.
I think the all up weight was a bit over 22 lbs, ???. |
| All times are GMT -8. The time now is 08:13 PM. |
