RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Field Gas Can & pump setup? (https://www.rcuniverse.com/forum/gas-engines-142/4309595-field-gas-can-pump-setup.html)
tuwood 05-23-2006 03:52 PM
I just purchased my first gasser (BME 30% Edge) and need to get a field fueling setup.
I went to the LHS today & all they had was the dave brown hand pump for gas. None of the guys there had any gas experience so they couldn't offer much advice.
Do I just get one of these & a walmart gas can, or does somebody make a cleaner setup?
FYI, I bought the DA fuel dot for my DA-50-R so I think I have that end covered.
Thanks in advance.
Digger44 05-23-2006 04:49 PM
RE: Field Gas Can & pump setup?
I bought one of these with the hand crank and it is done right.[link=http://www.jerseymodeler.com/index.html]Jersey Modeler[/link]
Richard L. 05-24-2006 01:06 AM
1 Attachment(s)
I have the 1.25 gal Jersey Modeler jug. Very nice setup. You can order it from RCU Market Place, Chief Aircraft, or BCMA Engines: [link]http://www.bcmaengines.clearwire.net/fuelaccessories.htm[/link]
Zeeb 05-24-2006 06:56 AM
I tried one of the "do it yourself" things then went to this;
http://www.slimlineproducts.com/online_shop/m1_gas.htm
Mine's about a year old and looks a bit different, don't know if the picture is the older model like my buddy has, or if they've gone back to it but it works well and should have the F1 fittings for your fuel dot. Or at least I think that's what the DA dot uses... :eek:
tuwood 05-24-2006 07:09 AM
Thanks guys, this is exactly what I'm looking for.
I'll check out the different ones & get one on order.
JoeAirPort 05-24-2006 07:54 AM
This one ain't cheap but it rocks. Very convenient to mix oil with that big opening.
ORIGINAL: Richard L.
tuwood 05-24-2006 07:59 AM
ORIGINAL: JoeAirPort
After spending all the money for a new 30% Edge, a $50 fuel setup is really cheap. :D
