RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Prop Bolt Patterns (https://www.rcuniverse.com/forum/gas-engines-142/4422519-prop-bolt-patterns.html)
shakes268 06-23-2006 01:03 PM
Prop Bolt Patterns
Hi guys,
Does the DA-100 and 3W share the same bolt pattern? I ordered a tru turn spinner - drilled for a DA-100 and cut for a Mej/Menz prop. I received it this morning and it reads "3W 80" on the label. If its the same bolt pattern, I hope the slots are cut big enough to accomodate a 27x10 or 28x10 prop. I had to come into work so I haven't been able to try it.
flyinrazrback 06-23-2006 02:56 PM
RE: Prop Bolt Patterns
Yes, the bolt patterns are the same
