Anyone using a da150 muffler set on a DA100 engine?
Is anyone using a DA150 muffler set on a DA100 engine?
Does the noise level drop noticiably? Any rpm differences? Looking at a new setup and would like setup to make less noise. Thanks, Tony |
RE: Anyone using a da150 muffler set on a DA100 engine?
ORIGINAL: tkilwein Is anyone using a DA150 muffler set on a DA100 engine? I seriously doubt it. It would take to much modification of the muffler or an intermidiate piece between them. Does the noise level drop noticiably? I agree, the DA100 on stock mufflers is loud, but I doubt a set from a 150 would quiet it down. Any rpm differences? The stock mufflers are probably so unrestrictive that nothing would be gained, but iddle may suffer. Looking at a new setup and would like setup to make less noise. Go with cans, possibly make your own from Bud/Bud Light 16oz aluminum bottles. Thanks, Tony |
I got a answer from DA on this.
The cans need to move out - drop down and standoff between motor and backplate mount. I can mill this adapter out but not worth it, going with stock setup for now. I will make a custom muffler for another engine I have out of warranty and try on. Thanks, Tony |
| All times are GMT -8. The time now is 03:27 AM. |
