RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Wing Loading and Cubic Wing Loading (https://www.rcuniverse.com/forum/gas-engines-142/4865058-wing-loading-cubic-wing-loading.html)
3d-aholic 10-13-2006 08:43 PM
What is an acceptable wing loading for flying good 3D on a 27-28% plane?
Is a wing loading of 30.45 oz/in or a cubic loading of 9.76 oz/cu. ft. ok?
AirWizard 10-13-2006 08:56 PM
RE: Wing Loading and Cubic Wing Loading
IMO 23 to 25 oz/in
3d-aholic 10-13-2006 09:01 PM
Can't be...[X(]
Using this site here...http://adamone.rchomepage.com/design.htm
A EF YAK with a DA50 at around 1400sq and 15.5lbs...is 25.51oz/sq ft. and is that about one of the absolute best case scenarios...yet its already slightly past your highest range.
Tired Old Man 10-13-2006 10:10 PM
Cubic loading unneccesarily complicates the computation. Your plane would fly well at 34 oz/sq. ft. depending on available power. More power makes 3D possible. Average power means standard aerobatics would be the area flown.
3d-aholic 10-13-2006 10:20 PM
ORIGINAL: Silversurfer
Well it would be a 58cc on a 28% so I think there would be plenty of power....thats why I'm trying to determine if the combination works and how far I'm into the "lead sled" arena.
rmh 10-13-2006 10:28 PM
for really good 3D that size is better at 25 -- My own EF YAK weighed 15.25 with piped ZDZ50 -turning Mejzlic 22x8 at 7750 static
instant acceleration and super slow falling maneuvers
lots o power and min weight is the 3D formula- no way around it
but -- my 39 lb pig of a 42% at 2600 squares -is 34 lb loading and is also a "feather " relatively. just not the acceleration of the YAK
My EDGE at 23 lbs and 1650- is close to 33+-- not as good at slow 3D but still very good at power maneuvers. Lots o power.
30 - is a decent number for most stuf -in THAT size ---- but lower is better -
now go to really good electric flat foamies - the power to weight is far far better and the performance is like a hummingbird
wing loadings of 3-4 ounces per sq ft.
AirWizard 10-13-2006 11:16 PM
AirWild Extra 260 has a 24.8 oz/in
Flip and Fly 10-14-2006 03:54 AM
Don't forget that there is a scale effect, the more wing area "over all" the higher that number can go I think.
Like on a 28% I would go no higher than 30 oz/in. ( depending on your location, altitude, air temp) for good 3d.
On a 35% you can go to about 32 oz/in and have the same result as the 28% on 30 oz/in.
On a 40% you can go to about 34 oz/in and it will fly like a 28% at 30 oz/in.
Or so it seems to me.
Also altitude were you fly, and temperature, will have an effect on lift.
Cooler air = more lift
Denser air = more lift :D
rc bugman 10-14-2006 06:59 AM
Hi,
If you want to "design" planes of different sizes to fly similar, you need to use the cubic loading formula for comparison. Simple oz/sq ft calculations are not represensitive. thus the saying "larger planes fly better" For example, a 25% cap with a wing loading of 25 oz/sq ft will fly the same as a 33% cap with 32 oz/sq ft, etc. (these are just figures to illustrate the concept, not actual calculations)
Elson
Flip and Fly 10-14-2006 08:24 AM
I agree, its what I was saying. Without having to get into all the formulas it was just worth noting that.
By the way what is the formula.
Thanks.
3d-aholic 10-14-2006 09:51 AM
Yes, cubic loading is suppose to be something you can compare across plane sizes. For example, a EF Yak87 at 5.5lbs would be a cubic loading of 8.18. I'm suggesting a cubic loading between 9.24 (best case) and 9.76 (worst case).
[link=http://adamone.rchomepage.com/design.htm]Heres the formula.[/link]
Flip and Fly 10-14-2006 10:04 AM
Thanks, that is well illustrated.
Flip and Fly 10-14-2006 10:49 AM
I used the cubic loading program to see what I get with my 3D planes.
1/4 Extra is 28.8 oz/sq ft wing loading.
Cubic loading for that one is 10.33.
In the real world it flies light, good 3D!
35% Ultimate is also 28.8% wing loading.
Cubic loading for that one is 7.58.
In the real world it flies very light too, good 3D. I find it just a little better than the little extra, but then its a bipe, two wings seem to get less lift that one big one over all.
35% Extra with a whopping 34.21 oz/sq ft wing loading.
Cubic loading for that is 9.81! Hmmm, less than the little Extra, even with a much higher wing loading.
In the real world it flies as light as the little extra, soooo I can verify from my experience that its all rather accurate.
3d-aholic 10-14-2006 11:27 AM
Ok great...yes...hard to tell if those numbers mean anything in the real world...and you have 2 out of 3 that are above the cubic wing loading I suggest so perhaps its doable then.
Flip and Fly 10-14-2006 11:33 AM
Looks to me like anything with a 10 Cubic wing loading, or close to it will 3D.
And I know how to 3D, I am talking slow 3D, rolling harriers, harriers, high alfa knife edge, avalanches, flat spins, all that cool stuff :)
