BME 50cc problems
my engine this outside time that I must do so that it works well?
thank...!! |
RE: BME 50cc problems
Put this jacket on and come with us...
I think his engine is out of time and he wants help
Or maybe the engine requested a time-out?
Holland man to Florida man: "explain please". |
yes my engine is out of time...
If it has used up it's allocated operating time frame, send it in to BME. They will know how to re-instate it to perfect running condition again.
How much 'time' did you get with it when you bought it ??
sometimes when you are out of time, you can replace time with whack (unless of course you are also "out of whack")....
That's the problem with getting older. There's never enough time to get things done, and even less time left before you're done.
In this case, probably the best way to fix your timing issue would be to send it to BME. Keep in mind that if you were to use a Timex it would take a licking and keep on ticking. |
I thing ...... best is to send to bme
Thank... |
Yup. Timing is everything.
A stich in time saves nine.
| All times are GMT -8. The time now is 05:20 PM. |
