ryobi vibration mount?
I haven't noticed any anti-vibration mounts available for the ryobi conversions. Is vibration not a problem on these engines? Thanks. Mike
Vibration is always a problem, but you don't have to use a soft mount. Sometimes the soft mount can make things worse.
Thanks for the reply. I am contemplating converting a Ryobi 31cc for the Olympic Telemaster that I am building. So far I have seen no problems using this motor.
Mike. |
RE: ryobi vibration mount?
Mike,
What is the Olympic Telemaster, and did you ever build a Telemaster 150? Thanks, Doug |
We built a 12 foot Telemaster, weighed 19 lbs, flew fine with a G38, 20-8 prop, 7000 rpm..
Did you build from a kit, plans or scratch? I'm trying to find a kit, or maybe some instructions to go along with the Hobby-Lobby Telemaster 150 plans. The plans leave out details such as Engine, radio etc. I'm not quite experienced enough to build it without at least some instructions.
A kit would make it even better. Thanks, |
| All times are GMT -8. The time now is 01:53 PM. |
