Differences in Brison 2.4?
I am considering a Brison 2.4 for a ultra rc 29% Giles 202 and have seen some Brisons have a satin case and others are polished. Is there a difference internally between the two? I am also looking at the ZDZ 40rv, too many choices can't make up my mind. Thanks for any info.
RE: Differences in Brison 2.4?
yes there is!
1. the old ones- unpolished - have an advanced timing mechanism that is attached by 2 rods to the carb TH and to the pickup sensor mobile Teflon ring , this way the sensor !QUOT!moves!QUOT! as the TH does respectively. 2. the new ones- polished - have a fix-point sensor and an additional elec unit in between the sensor wire to the ignition unit. brison are great engines, just be aware tht brison have changed owner lately, and some users here have complained about start-up troubleshooting after 30min of work...? my suggestion, double check your self and the product you getting....( good for other things in life :D ) |
| All times are GMT -8. The time now is 04:44 AM. |
