Conversion Engine
I need some advise from you pro's. I am just getting in to bigger engines and need to know what you suggest for a 2.3 cid conversion engine. As you all do I would like to stay as light as possible but also have the power. THANKS FOR THE HELP
Conversion Engine
I just converted a Poulan 42 cc (2.5 Cu.In.) Chainsaw engine.This engine looks to be a performer! I have to do some Bench running yet before I can post the numbers. Total weight with 18" prop, Spinner , and mount is 3 lb. 14 Oz.
| All times are GMT -8. The time now is 08:56 PM. |
