Engine Mount for EV0 35
Season Greetings :-) I have a Evolution EVO 35 that uses a standard beam mount. Problem is that I cannot find a good alum beam mount that is rated for this large of engine. I would prefer something with some dampening action but will consider anything at this point. Dubros makes one that is rated for a 180 4 stroke and it appears to be big enough just worried about the rating. Thanks for any help.
Best regards, Randy |
RE: Engine Mount for EV0 35
See Item 3398R at http://www.mvvs.nl/MVVS/main_bestanden/pricelist.html
This is a red anodise radial mount, to wich you can add isolators of your choice. |
| All times are GMT -8. The time now is 10:30 PM. |
