RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Evolution Gas engine (https://www.rcuniverse.com/forum/gas-engines-142/5162669-evolution-gas-engine.html)
reincarnate 12-26-2006 10:08 AM
Anybody out there running one of the Evolution gassers? LHS has one of the 26GT's and without plunking down $375 to experiment I look to the sage wisdom offered here. Weight-power ratio is amazing, but does it cut the mustard? As a note the other gasser I was looking at is a Zenoah G26 (almost 2x weight!)
ncrego 12-26-2006 10:23 AM
RE: Evolution Gas engine
Do a search, you'll get hundreds of posts on them, and their twin, the MVVS 1.6. I have one, it's a great engine, makes good power, runs well, and as you said, reasonably light.
laryboy 12-26-2006 10:49 AM
i have one of each and are happy with both
pe reivers 12-26-2006 01:25 PM
evolution and MVVS are one-egged twins. Do a search on both, and you will find a wealth of information.
The MVVS 160 is by far the most powerful gasser in it.s class with power just shy of the OS 160 FX
frieshoo 12-26-2006 04:42 PM
The MVVS 1.60 (Evolution 26GT) is very strong, and reliable. Installs easy, Setup is easy, and Starts easy.... The price is high, and you must get a good muffler.... The wrap around pitts that Horizon sells is a good one... and tuned silencer from MVVS is very good...
I ran mine on several models.... 74inch Staudacher 13lbs.. great IMAC plane
84inch Taylorcraft 17lbs.. again great flying model
Hanger 9 Funtana 90.... good 3der
80 inch BalsaNova.... would hold hover at about 60% of throttle... 18x6Evolution wood prop, and tuned
pipe.
Richard L. 12-26-2006 05:45 PM
ORIGINAL: frieshoo
Wow, didn't know the 26GT can pull a 17# plane. Is the engine really that powerful?
pe reivers 12-26-2006 05:59 PM
Mine pulled a 18 lbs tow plane + 12 lbs glider both in piggy-back or tow using tuned pipe and 18x8 menz or similar props.
Tow plane only could perform sedate aerobatics.
tailskid 12-26-2006 10:10 PM
My P-47 is a bit over 17 pounds and the 26GT makes it fly scale-like - some vertical, not a lot. Interesting throttle response - it is almost idle or full with very little in between.
reincarnate 12-26-2006 11:27 PM
Sounds potentially problematic. Are you saying you are pleased with the engine or otherwise? With little in between, hows fuel consumption?
ncrego 12-26-2006 11:44 PM
Mine doesn't have that kind of throttle response at all, it's very linear. Mine is installed in a Hangar 9 SuperCub (actually, one I purchased from tailskid), and it's an awesome engine, it flies very scale like at 1/4 throttle, and full throttle is pretty close to vertical. Fuel consumption on mine is ridiculous. I've flown it for 45 minutes on the 20oz tank I have in it, and still had plenty of fuel left. Of course, it's a Cub, so it was all at low throttle, but still impressive. I think it's a great engine, I'd love to have another one.
tailskid 12-27-2006 12:19 AM
I agree with the fuel consumption - or what little there is :)
