RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Ether When Starting (https://www.rcuniverse.com/forum/gas-engines-142/518714-ether-when-starting.html)
BATRIPP 01-29-2003 06:12 PM
Ether When Starting
My engines are magnito and after choking to get fuel up to carb, I have gotten into the habit of giving them a little squirt of ether (motor cold). Seems to make kicking them off much easier.
Has anyone got any experience with this practice and will it damage anything?
BT
Antique 01-29-2003 06:29 PM
Ether When Starting
Your engine if you use too much and your hand if it gets in the way :D
CAPtain232 01-29-2003 09:29 PM
Ether When Starting
Simply not worth it.......Too much at stake
Kris^ 01-30-2003 01:29 PM
KABOOM!!!!!
Ether of any sort is just NOT a good idea. It may kick the motor over and get it going easier, but it can also kick back a lot harder than gasoline and snap/slice fingers. I've seen many Zenoahs that are one-flip runners, with magneto and gas, no help at all. Seems tuning and a bit of practice are the better path in this case.
gone. 01-30-2003 02:06 PM
Ether When Starting
With my US Engine 41cc and when I had the 23 cc I use WD-40. It makes a good starting fluid - matter of fact it's about the only "good" use I've found for it! So far it hasn't done any damage in 4 years to my 41 cc gasser.
Kris^ 01-30-2003 02:26 PM
WD-40 MUCH better
Unlike Ether based starting fluid, WD-40 is a liquid and burns much slower, although a bit hotter than gasoline. It also is "vaporized" slightly as it is squirted into the engine, which makes it burn more easily than raw gas that is still in liquid form. Remember, it's not the "liquid" that burns, but the gasses given off as it evaporates/changes to gaseous state, that burn. You could, given enough effort, burn Coal (yeah, the black hard stuff) if it was a fine enough powder that it could be injected into the engine, and they have actually done experiments with "Coal dust' diesel engines.
wiggles 01-30-2003 02:45 PM
Ether When Starting
If you have been starting your engines with ether long enough, they get a liking for it and won't start without it.
captinjohn 01-30-2003 03:32 PM
coal dust
I am not sure but I think the very first internal combustion engine ran on coal dust??? Capt,n
Kris^ 01-30-2003 03:52 PM
Ether When Starting
You got me. . . anything is possible Cap.
tkg 01-31-2003 02:07 AM
OLD stuff
CJ
The first internal combustion engine ran on GUN POWDER. Wonder what a rich mixture did :)
The first Diesel ran on coal dust
causeitflies 02-05-2003 02:24 AM
Ether When Starting
I don't think WD-40 burns at all. The old WD40 was pressurized with Pentane which did the burning. The newer WD40 uses a nonflammable propellant and will not work.
gone. 02-05-2003 10:38 AM
Ether When Starting
Don't tell that to my engine - - please!
Jemo 02-05-2003 12:39 PM
Ether When Starting
I never heard of coal dust used in engines but it is used all the time in large steam boilers. The coal is pulverized and injected into the boiler just like oil would be.
Bison 02-05-2003 06:12 PM
Ether is extremely flammable
I'm a professional chemist as well as an R/C flyer. I would never use ether at the flying field because of it volatility and flammability. Ether is hazardous enough to use in a well equipped chemical laboratory.
captinjohn 02-05-2003 07:40 PM
IS TOPIC EHTER OR STARTING FLUID
I do not think people are getting strait ether to start RC engines. Maybe the model diesel engine owners do. It is my opinion that the starting fluid you buy at walmart is not dangerous if used properly. And in small amounts only when needed. I am talking like in cold weather also. Captinjohn :)
xp8103 02-06-2003 02:23 PM
Ether When Starting
Heck, a can of starting fluid was REQUIRED field box fodder when I was growing up. Dad used a squirt in the carb of his old Merco's to get them going in the winter.... :)
captinjohn 02-06-2003 02:57 PM
starting
NOW THERE IS A COUPLE OF SMART RC-ERS Capt,n J :)
