RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Possible CDI conversion (https://www.rcuniverse.com/forum/gas-engines-142/5241550-possible-cdi-conversion.html)
coralcape 01-10-2007 08:18 AM
Have recently bought a tartan twin glow. I want to convert it to CDI. I have several CDI units for single cyl. Can I use one of them and parallel another high tension lead and drive two plugs? The CDIs are C-H and BCMA. Good luck, red
dirtybird 01-10-2007 08:47 AM
RE: Possible CDI conversion
No you cannot parallel spark plugs. That is why they have two coils in a twin unit.
You could use two CDI units and drive them with one Hall affect device.
soarrich 01-10-2007 09:13 AM
First you may want to check that the motor has roller bearings on the big end of the connecting rod, if it doesn't stick with glow fuel.
Ed Vollmer 01-10-2007 10:40 AM
ORIGINAL: soarrich
Tartans have needle bearings on both ends of the rod. Usual gas mix is not a problem. The carburetor will have to be changed to a gas carb. Otherwise the needle settings are very, very sensitive due to being enlarged passages for alcohol.
coralcape 01-12-2007 10:21 AM
Thanks for the replys. I guess I forgot the law that says electricity takes the path of least resistance :o) Good luck, red
