us 25
Hello,
I have a us 25 engine (new) without the starter. The muffler broke from vibration at the header. I'm going to try to braze it back together but it will still be very weak because of the mass that's hanging behind the motor unsupported. Does us engines still have these mufflers? DO you have a can-type muffler that will fit this engine? Mine has run really well and flies my byron pipe dream great with a 17-8 prop at about 7400-7700 rpm. thanks for your help, craig |
us 25
Craig,
The only muffler we've had for the U.S. Engiens 25 cc engine was the stock one. Unfortunately, it's been discontinued, and so there are no more available. The only source of a muffler for your engine would be form one of the after-market manufacturers. We're sorry we don't have better information for you. |
us 25
BAX,
I hope you have one in stock. I'm sendin mine in. It's still under warranty (2 years) and as far as I can tell from the literature that came with the engine it should be covered. Craig |
| All times are GMT -8. The time now is 10:44 PM. |
