RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BROKEN NEEDLE HELP (https://www.rcuniverse.com/forum/gas-engines-142/5369014-broken-needle-help.html)
Big Joe 1 02-04-2007 09:56 AM
BROKEN NEEDLE HELP
CAN ANYONE TELL ME WHY MY HIGH END NEEDLE ON A TRAXXAS PRO .15 NITRO MOTOR HAS BROKEN TWICE IN TWO DAYS. IT'S BEEN IN THE UPPER 20'S AND 30'S. WOULD AIR TEMPERATURE HAVE ANYTHING TO DO WITH IT?
v-snap 02-04-2007 10:24 AM
RE: BROKEN NEEDLE HELP
How long is it? It could be vibration is it to actually bend in a cyclic fashion untill it breaks. I have seen this on Airplanes with extended needle valves. It is amazing at how far they will actually bend when you hit the correct cycle.
Big Joe 1 02-04-2007 10:38 AM
IT PROBABLY ABOUT 1 INCH TALL OFF THE CARB.
