Ignition module mounting
I'm getting ready to finalize my setup on my 330L and was wondering how guys are mounting their ignition modules? At this time I'm leaning on mounting the module to the side of my engine box. If I go with this method, what is the preferred way of securing the module (e.g. zip tie, velcro, or rubber band)? If anyone has any ideas or prefered methods that have worked well for them in the past, I would appreciate if you could share.
Thanks! |
RE: Ignition module mounting
Use a cutting wheel on the dremel. Cut a couple slits in the side of the engine box. Slip some velcro through the holes. Add some foam padding and strap it right to the side of the engine box.
Some require more cooling than others, All depends on what type of ignition. Which do you have??
I mount mine between rubber bands X-wrapped around the engine stand-offs. Completely shock proof and lots of air circulating around the unit.
I have a Falkon ignition module on my ZDZ 80 RV.
| All times are GMT -8. The time now is 04:45 AM. |
