engine selection
Hi, I am building a 28% Staudacher from Bruce Lund plans. I have been flying and building for 30 years but have little gas experience. What engine would you recommend for a 80.5" aerobatic model. For me cost is a major factor so will be looking for the best value not necessarily the most powerful engine. At this time, 3D with an aircraft of this size does not interest me but I do like to have some verticle performance. I also realize a model of this size will be flown on the wing more than my 40's. What size and where should I look. Thanks, Dave
RE: engine selection
For the money, and for the power, a Briellelli would be a good choice. So would a 3mm 53 that Wild Hare is selling. Whichever is the least expensive at 50cc plus would be a good selection. Both are relatively light. Both perform well. Neither are what would usually be considered expensive for a gas engine in this size. Your plane may not need to fly nearly as much "on the wing" as you think. I believe you will be pleasantly surprised. Both engines are less expensive that the other "names" in the 50cc class. Both are reliable with good power and mid ranges.
Take a look at copperhead aviations venom 45cc,or even brillelli's 46 cc. Cant go wrong with either one,as i own both. Also have a fuji 43 on an 80inch omp edge,at a tic under 14lbs the thing is unstoppable,very happy with them all.
Try a 52cc twin from knoxhobbies..Engine Specifications
Piston displacement 50.8cc Output 4.2 h/p Bore 34mm Stoke 28mm Carburetor Walbo pump type Spark plug resister Weight 3.75 lbs with mufflers and ignition Auto advance electronic ignition 4.8 to 6 volts Propellers 20x8 8000rpm, 20x10 7100rpm, 22x8 7100rpm Speed range 1400 to 9000rpm Fuel 25 to 30 to 1 for break in period Fuel induction reeds |
| All times are GMT -8. The time now is 07:07 PM. |
