3W-24 engine
Is the 3W-24 a very powerfull engine? And of coarse, where is the best place ot purchase them? Thanks Captin John
3W 24
At least as good as anything else out there, probably better than most..Cactus Aviation, ask for Bobby...R C ....
3W-24 engine
The 3w-24 is the most powerful 24 cc made. It has the same power as a G-38 but only weighs 45+ oz rather than 80+ oz. I use this engine in my university research and I own 15 of them. I have run this engine many hours. It will turn an 18 x 8 at 8000 rpms. The torque peaks at ca. 7500 rpms so the best prop for sport flying is an 18 x 10 which the engine will turn at 7300-7500 rpms.
I have had excellent luck purchasing engines from Aircraft International in NJ. Check any model mag for the address and URL. Gerhard has provided me with excellent service. I have some engines pushing 100 hrs of full bore running and these engines are still turning 8K. Elson |
RE: 3W-24 engine
Hi Elson-
I am about to brake this engine in, which is already installed in a GP 120 Super stearman (ARF). Question: Could I just burn 2-3 20 oz. fuel tanks and then fly it, or should I take it onto a stand? And what kind of prop would you use to brake it in and which one to fly, I know now for your previous post that a 18X10 for sport f. will do it, but what brand? Many thanks. Enrique. ORIGINAL: rc bugman The 3w-24 is the most powerful 24 cc made. It has the same power as a G-38 but only weighs 45+ oz rather than 80+ oz. I use this engine in my university research and I own 15 of them. I have run this engine many hours. It will turn an 18 x 8 at 8000 rpms. The torque peaks at ca. 7500 rpms so the best prop for sport flying is an 18 x 10 which the engine will turn at 7300-7500 rpms. I have had excellent luck purchasing engines from Aircraft International in NJ. Check any model mag for the address and URL. Gerhard has provided me with excellent service. I have some engines pushing 100 hrs of full bore running and these engines are still turning 8K. Elson |
RE: 3W-24 engine
Hi Elson-
I am about to brake this engine in, which is already installed in a GP 120 Super stearman (ARF). Question: Could I just burn 2-3 20 oz. fuel tanks and then fly it, or should I take it onto a stand? And what kind of prop would you use to brake it in and which one to fly, I know now for your previous post that a 18X10 for sport f. will do it, but what brand? Many thanks. Enrique. |
| All times are GMT -8. The time now is 07:21 AM. |
