RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Fuji BT-32 B interference (https://www.rcuniverse.com/forum/gas-engines-142/5867733-fuji-bt-32-b-interference.html)
anonymouse 05-17-2007 05:12 PM
Have a two or three year old Fuji BT-32 and all of the sudden am getting radio interference. Cannot get more than 30 FEET on radio range check with engine running. Have tried two different recievers on two differeft freq's. Changed plug. Checked for any loose metal to metal chatter, done everything I can think of except change ignition module. Not much info from Fuji, except to tell me to do everything I have already done. Anyone have a suggestion other than get a "good" engine? [:o]
sw phil 05-29-2007 03:03 PM
RE: Fuji BT-32 B interference
I had this problem and cured it by stripping some TV co-ax, and using the screen to screen the H.T lead and plug cap. Held it in place with heat shrink, and grounded it to the engine body.
anonymouse 06-09-2007 08:06 PM
The magic toush for sure, it solved the problem!!!!!
