RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BME 50 Header needed (https://www.rcuniverse.com/forum/gas-engines-142/5874961-bme-50-header-needed.html)
SAL98 05-19-2007 03:25 PM
Does anyone know where I can find a wrap around header for a BME 50 engine? I dont know if the bolt pattern is similar to any other engines, but if it were even that would be a help. I would like to put an MTW TD75K can on a new Wild Hare Honda scheme Sukhoi.
altavillan 05-19-2007 03:56 PM
RE: BME 50 Header needed
If it's an echo pattern, (the bolts are at oposite corners) then you can make one from the parts that http://www.aircraftinternational.com/ sells. Macs products in Sac. Ca. can make custom stuff too.
altavillan 05-19-2007 03:59 PM
If its a DA or 3W type (bolts strait across) then you can usualy file a grove in the header to make the bolts fit.
SAL98 05-19-2007 05:23 PM
Thanks altavillan, I will check the bolt pattern. I forgot that a header uses through bolts to hold it on, not threaded holes. Info is greatly appreciated.
blkbird68 05-21-2007 11:52 PM
Karl Mueller can make you a custom one for the BME 50 out of alum. Made to your specs. He is making me a set for a BME 110 right now.
RTK 05-22-2007 12:11 AM
blkbird68--does Karl have a web site??
blkbird68 05-22-2007 02:40 AM
[email protected] is his email
And Aerobob has a page on his about Karl's work....
[link=http://www.rcaerobats.net/Mueller/MuellerCustomHeaders.htm]RC Aerobatics-Mueller headers[/link]
RTK 05-22-2007 08:33 AM
SAL98 05-22-2007 04:42 PM
Thanks for the info
