RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   How Do I Wire an Ignition Kill on a DA50? (https://www.rcuniverse.com/forum/gas-engines-142/5912706-how-do-i-wire-ignition-kill-da50.html)
dabevan 05-28-2007 02:55 PM
Ive got a Desert Aircraft DA50 and I want to wire in an ignition kill switch.
I could just add a switch that will disconnect the ignition battery, but with my other gas engine (a Quadra 42) I cut the engine by shorting the LT lines (ie the ones comming from the magnetic pick up).
The advantage of shorting the LT lines as oppose to disconnecting the battery is that if the switch fails (ie goes open circuit) then the engine continues to run where as with the 'disconnect' method a failed switch would stop the engine.
...The problem I have is that the DA50 has three LT lines where as I would normally expect either 2 lines or 1 line (using case as earth)
Does anyone know how DA have wired up these LT lines and if its possible (ie without damaging the module) to cut the engine by shorting the LT lines.
David Bevan
Antique 05-28-2007 05:24 PM
RE: How Do I Wire an Ignition Kill on a DA50?
There are only 2 wires used in the DA engine.The third is not connected to anything...It WILL stop if you cut one, but the ignition will still be connected to the battery...There is no other way, use a switch in the power line....
RTK 05-30-2007 12:17 AM
Smart fly optical kill switch, works from the transmitter too.
bipeaddict 05-30-2007 08:06 AM
I second the use of the Smart-Fly optical switch. How to article and be seen here
http://www.rcuniverse.com/magazine/a...article_id=375
