Adjusting throttle sensitivity.
By the time the throttle stick is at about 1/3 of it travel my engine is at approx 85% full power, making the throttle near idle very sensitive to even the smallest of movements. Other than adding some negative expo to the throttle is there any other way of reducing the throttle sensitivity.
Karol |
RE: Adjusting throttle sensitivity.
Larger prop. longer throtle arm, set the servo arm so that at idle it is pointed almost strait back.
ORIGINAL: karolh By the time the throttle stick is at about 1/3 of it travel my engine is at approx 75% full power, making the throttle near idle very sensitive to even the smallest of movements. Other than adding some negative expo to the throttle is there any other way of reducing the throttle sensitivity. Karol |
Put a larger throttle arm on the carb and a smaller one on the servo. You should make it so your atv or end points are atleast 100% this gives you good resolution and full stick movement. Personally if you can get it to 120 or 140 then you are doing very well.
My Futaba radio has expo function availability on the throttle but I would much prefer to keep it deactivated and reduce throttle sensitivity by a mechanical adjustment, so I will certaintly give your suggestion a try and see how it works out.
Karol |
WHY??????? You paid to have those features/capabilities, and expo can be easily changed. Mechanical settings are difficult to tweak, and can't be done easily while engine is running. Expo can be tweaked while the engine is running, making it much easier to get it like you want it..... but.... to each his own. ;)
I guess when one looks at it in that light you are dead right.....another true example of the saying " two heads are better than one ". Will use the expo to soften up the throttle. Thanks guys.
Karol |
on my 9c -30% expo is a great starting point
Will see how 30% feels for starters on my 8UAF.
Karol |
Yup, I run my gassers at -40% on my 9c.
ORIGINAL: 3dd on my 9c -30% expo is a great starting point |
Expo will soften up your idle to 1/4 + throttle... but ultimately from 1/3 or 1/2 + you will still be hyper sensitive. It depends what your ultimate goal is. You would get closer to a true response by leaving the arms the same length and adjusting both end points and using just a touch of expo.
The only way to get a true throttle curve with an accurate response to get full resolution. I always try to get atleast 100 / 100 on my end points for throttle and might use 5-10 expo at best but usually its not needed at that point. Sometimes a little bit does help though... |
My end points are at 120 both ways and the carb arm is longer than the servo arm. I think my problem lies in positioning the servo arm correctly on the output shaft. I already had -20 expo dialled into the throttle and was still having a problem when I started this thread. This is the first time I'm having such a difficult time in getting it right.
Karol |
Karolh
Set the servo arm in line with the throttle push rod at idle, that way you get very little movement up the begining of the arc at low throttle and more movement as the servo gets towards the top of the arc, the correct way is to take a tach reading at idle and at WOT then set your carb and servo to give half the difference at mid stick, setting up either on the Tx or mechanically, I do both. Mike |
Sounds to me like it's not set up good. When you did this, was the engine closed and the throttle and trim switch down completely on the tx and servo closed with no mixing when you attached it?
ORIGINAL: Trollmaster Sounds to me like it's not set up good. When you did this, was the engine closed and the throttle and trim switch down completely on the tx and servo closed with no mixing when you attached it? Karol |
be sure you are using - expo,+ expo will speed up the low side throttle
That little sucker caught me once. Sure can laugh about it now, but it was no fun back then especially when you are in the air and it's on the elevator :)
Karol |
| All times are GMT -8. The time now is 06:56 PM. |
