engine will not start hot
I recently purchased a 30% carden extra 300 with what appears to be a sachs 4.2. Being new to gas I recurted help getting the engine ready to fly. anyway the engine starts great cold, but after its run a while and shut down it will not start back up until it has completely cooled down. I've changed plugs, battery,and switch, still the same problem. If I'm missing something please let me know.
Thanks in advance. Tim |
RE: engine will not start hot
Try choking it again for each new start. Sounds like the fuel line is getting hot sitting next to the engine.
i had that deal once and it turned out to be the diaphram in the carb, for your deal try richen up the low end just a smighen and see if that helps...
I'll try a new diaphram and give it a try. |
| All times are GMT -8. The time now is 12:53 PM. |
