RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Kill switch installation (https://www.rcuniverse.com/forum/gas-engines-142/6721325-kill-switch-installation.html)
Pilot013 12-06-2007 11:28 AM
Hi dear friends!
I have a GP Yak-54 and a Fuji-50EIS engine. I want to install a GP Kill engine switch. I read in the Tower hobbies explanation about the product, that it won't work with the EIS series. Maybe we should try giving here some ideas. Actually I don't want to install an additional servo, maybe we can do it, we lower the trim or something it to enable the Kill switch button. Actually I am not familiar with this particular element from the plane, so I'd be happy to hear your proposals and opinions!
Best regards! Waiting for your answer!
Jake Ruddy 12-06-2007 12:31 PM
RE: Kill switch installation
http://www.smart-fly.com/Products/Ignition/ignition.htm
altavillan 12-06-2007 12:46 PM
The switch needs to be depressed to be on. Until recently I used them for all my gas engines. I Just used another servo. To not have to use another servo I think a large round servo horn could be cut to opperate the switch using just the throttle servo.
Pilot013 12-06-2007 12:46 PM
Hm interesting! Thanks!
Hope sombody could show more ways to link the kill ignition switch!
Best regards!
Al Lewis 12-06-2007 02:46 PM
You wire it into a 6" extension. Just cut the red wire on the extension and solder the switches two leads to those. Then run that extension between your EI and power source. When the switch is off nothing should get through the red wire so the EI has no power to operate. Personally I use RCats Solid state switches. They're $25.00 and don't require a servo to operate.
http://rcatsystems.com/electronics/rc100.php
Pilot013 12-06-2007 03:04 PM
Thanks a lot Al!
The only thing I didn't understand is how I am going to make the ignition OFF during flight or let's say before landing?
Best regards!
altavillan 12-06-2007 03:52 PM
1 Attachment(s)
Left shows throttle closed engine killed. Right shows throttle open engine ignition on.
Pilot013 12-06-2007 04:21 PM
Hi!
This is very useful!
Thanks a lot!
I'll try to do this on my plane however my servo is side mounted.
Very good diagram. Hm I thought the left photo show a working ignition. Actually now I understand the whole situation. So Actually when the sensor is pressed, then there is spark and the ignition is working, right?!
Best regards!
altavillan 12-06-2007 07:30 PM
Yep. Depressed the circuit is closed, power flows. Or in the case of killing a mag ignition, depressed is kill by completing the loop to ground.
Magne 12-07-2007 09:11 AM
Pilot013,
A lot of these micro switches have selectable NO/NC (normally open or normally closed) depending on how you wire them.
That means, that they can be either on or off when you depress them, depending on your requirement.
Magne
Pilot013 12-07-2007 12:08 PM
Thanks for the useful info!
Best regards!
