FIX SPARK PLUG CABLE?
Hi, Bill and all,
I'm a happy owner of a Fuji 32 EI and unfortunately the cable that goes from the ignition to the spark plug was loose and a sharp edge cut it... Is there any way I can replace it? Or fix it? Or do I have to buy another ignition? :( Thanks for any help! Flavio |
RE: FIX SPARK PLUG CABLE?
The ignition unit will have to be replaced. Repair parts for the EI unit are not available.
Hello,
The ignition unit will have to be replaced. Repair parts for the EI unit are not available. Anyway, I solved the problem soldering the cable using a steel stick as a bridge and soldering the whole thing. The engine is working fine, no problem or RF leak. It solved the problem with the 5 bucks cable and saved me $160 dollars on a unit I don't need. Thanks anyway, Flavio |
| All times are GMT -8. The time now is 05:03 PM. |
