RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Da props (https://www.rcuniverse.com/forum/gas-engines-142/6779744-da-props.html)
AussiePilot 12-19-2007 07:38 PM
Da props
hey guys i just bought my second prop a Mejzlik 23x8 this will be my first carbon fiber prop, im comming from a
jxf wooden prop 22x8, ( DA 50)
alot of da flyer in auss recomend the Mejzlik so i thought id give it a try...
they say they are already balanced..thats good :)
So from all u experienced ppl just wondering what the pro's and cons are for my new [prop.? what will i expect from this upgrade:)
Hawk21 12-23-2007 02:38 PM
RE: Da props
You should check the balance, they come close but not perfect
at least the ones I verify. The Mejzlik 23x8 should give you more thrust.
My friend have been using a Mejzlik 23x10 in his extra 260 with good result for IMAC, it does not
spool fast but maintain a more constant speed. Give it a try and tell what you like from it.
What aircraft do you have?
