US 41 replacement HELP
Ive got a Pica 1/5 scale Spitfire that comes in at 25lb. The guy I bought it from has a US 41 in it. I want more power and I also need plenty of weight up front. Does anyone know which Gas I can go to that will closley match the US 41. I was hoping to keep the muffler side of my cowl from being cut. The US 41 has the muffler in the back. I thought about ZDZ but im trying to keep the price a little lower than that HELP :confused: :confused:
Quadra 52 has the same footprint (mounting) as the US - you may need to get a pitts type muffler to get the exhaust stacks behind the cylinder head, and, oh yeah, the carb is on the opposite side. Or you might try a Q52 carb and bennet muffler on your US.
Phil |
How does a Q 52 stack up in power to the US 41. The US 41 will turn a 20/8 zinger at 6700. The Q 52 having the muff on the opposite side might work because the side for the carb on the 41 is cut pretty good,enough for a bennett muffler. That would mean that I might could cut a small hole on the other side for the carb if I can skip the v stack ext. And your sure its the same foot print on the firewall THANKS LEE :D
Q52
Yes - the mounting holes are the same. I am not sure about the firewall to prop hub length, but you could shim that. I also know you can reverse the exhaust and carb by turning the cylinder and piston. You should get quite a bit more power by using the Q52. If you want a LOT more power get a BME 50 or new 55x. That would take a lot more remodeling work.
Phil |
Thanks Phil Im going to look into the Q 52 idea. It fits my budget better. Thanks so much for your advice Lee
Q52 is discontinued from Quadra but you might find a good used one. A tough reliable engine. I have 2 of them but wouldnt part with them.
BH - I agree that the US41 can be "improved" with the larger carb and with ignition, but then it gets lighter so you will need to add weight. Have you looked at a used Quadra 65 or 75? Way too much power, but the muffler is in the rear and you could limit the top end or run a multi blade prop with plenty of power to pull it.
Best replacement IMO would be a ZDZ 40RE to put the muffler in the back - add the weight you need for balance and the engine will be a good for the next airframe (when you get to that point). |
Q52
Check with Bennet For a Bennet built Q52. Not much difference in weight when you add up the electronics and the batteries required.
Phil |
Thanks for all the great advice. These warbirds need plenty of power ,especially when your a little green as I am . The added power is insurance. THe US 41 is a little small for a 25lb warbird. :D
BunkerHill -
Check out the RCU Classifieds "Gas Engines for sale". I believe I saw a couple of Quadra's listed at reasonable prices. You might also look up and contact William J. Krummel, Jr., you can do a search for him in RCU. He uses hopped up US41's on some big warbirds and swears by them! A real nice gentleman and very helpful. Phil |
US 41
How are you Phil? I saw your post about the little US 41 here and see that you gave the right advise. It will fly a 25 pound warbird very well with the modifications you suggested. I believe the carb is a WA 144 Walbro (available at B&B Specialties) My suggestion, if you do not have a noise problem at your field, would be to make a header pipe out of a flat piece of copper and a copper 3/4"elbow for the exhaust. The correct prop is very important on this engine and we have been using a 19x10 carbon fiber prop cut down to 18" diameter. Mine turns this prop at 7800 rpm. That will get your 25 pound warbird up and moving. :D
Another option is the Quadra Q 400. More power than the US41. A little less than the Q52.
| All times are GMT -8. The time now is 12:26 PM. |
