2.8 lb. engine?
Some where I have read about a fellow flyer getting a conversion down to 2.8 lbs. I think it was. But I can't remember where it was and unable to find it. Can anybody help out? Thanks
2.8 lb. engine?
yes that was my engine a 51cc stihl,type in (i did it lightest 56cc)
Darin |
2.8 lb. engine?
I'm also working on a Tecumseh 49cc. Right now it's at 3.0lbs less carb, hub, ignition and muff. I still have a large hunk of crank to cut off yet. My estimated weight, 3.2 to 3.4 lbs. Now, how well will it turn a prop.........we'll just have to wait and see.
2.8 lb. engine?
Thanks for the information. Post some #'s when your all finished if you would.
2.8 lb. engine?
I will post them in the Engine Conversions Forum when I get it done. Ignition and prop hub are on the way.
| All times are GMT -8. The time now is 02:04 PM. |
