RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   FUJI BT50EI ENGINE (https://www.rcuniverse.com/forum/gas-engines-142/7220722-fuji-bt50ei-engine.html)
dave06677 03-13-2008 07:14 PM
FUJI BT50EI ENGINE
MY NAME IS DAVE I NEED SOME ADVICE AND IF POSSIABLE A SOLUTION TO MY PROBULEM
I HAVE THE EXTRA 330 160 SIZE AIRCRAFT WITH A FUJI BT50EI ENGINE WHEN IM RUNNING THE ENGINE ALL MY SERVOS ARE GOING CRAZY FROM INTERFERENCE FROM THE ELECTRONIC IGNITION. ALL MY IGNITION WIRES AND SWITCH ARE 16 INCHES AWAY FROM ALL MY RECIEVER WIREING AND SWITCH.. I BOUGHT THE ED 111 ANTI GLITCH MODUAL FROM DYNAMIC ELECTRONICES BUT THAT DIDNT HELP EITHER WHAT CAN I DO TO SOLVE MY INTERFERENCE PROB
PLEASE HELP
RC Extreme power 03-13-2008 07:21 PM
RE: FUJI BT50EI ENGINE
Do you have metal from the throttle servo to the carb, Is the spark plug a Register plug, Any metal to metal contact anywhere
RC Extreme power 03-13-2008 07:26 PM
Some info here might be helpfull
http://www.rcuniverse.com/forum/m_7107316/tm.htm
