RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Prop for a MVVS 45cc engine (https://www.rcuniverse.com/forum/gas-engines-142/7249362-prop-mvvs-45cc-engine.html)
jaka 03-19-2008 11:48 AM
Hello!
How big prop for a MVVS 45cc engine with cannister (MVVS 3206) silencer??
karolh 03-19-2008 01:19 PM
RE: Prop for a MVVS 45cc engine
Try a 20x8 or 20x10.
Karol
the Wasp 03-19-2008 02:57 PM
""Try a 20x8 or 20x10""
larger than that !!,, MVVS are top quality engines that produce top performance, tuned for flight I get 7100 with a 3W 20x8 on my MVVS 35cc gasser,, on your 45 try a 22x8 or 23x8..
Jim
jaka 03-19-2008 04:41 PM
Hi!
Thank's !
MVVS says 24x10 Menz or Mejzlik but I think this might be too big.
pe reivers 03-19-2008 05:08 PM
20x10x3, 22x8, 22x10, 22x12, 23x10, 24x8
on the 3204 canister a 24x10 is possible
closetguy 03-19-2008 06:36 PM
i like Mejzlik 22-8 on a evolution pitts muffler at 7250 :D
pe reivers 03-20-2008 09:42 AM
The larger props are needed if you have noise limits. That also would prohibit the use of a pitts muffler.
The engine indeed tunes best if allowed to run at ~7000 rpm
jaka 03-20-2008 11:11 AM
1 Attachment(s)
Hi!
What about header lenght?
I have soldered a together a Krumscheid header pipe and is there a "best" lenght???
pe reivers 03-20-2008 01:47 PM
Jan,
Of course there is a best length. I have run a series of tests lately, that confuses you ad infinitum.
For the MVVS header I can tell you that 300mm is about the best for sub6000 rpm. our header seems a lot longer than that.
Thinner headers reduce power, but broaden the power peak
thicker headers shift power band up and narrow the peak
run a series of test using different props. This will show you the peak power rpm (use my prop power calculator, download from my web). Plot the curve, and you will know what to do!
the Wasp 03-20-2008 03:04 PM
I'm a strong believer that more than half of the average flyers out there are twisting the wrong prop (s),, why are these guys revving their G38 at 8300 with a 18x10 in a 16, 17, 18 pound Biplane when a 20x6 turning around 7000 would be much much more efficient, and at 7000 the engine would not be over revving out of it's torque range,, same old story I guess
Jim
Marcol 03-20-2008 03:08 PM
ORIGINAL: karolh
Karol
Perhaps you've only used Zenoahs ! :D
MVVS are a high performance engine.
Those props are way too small. My MVVS 35 turns a Menz 20 x 8 at 7000, so you'll need at least a 22 x 8 or even larger for the 45, which is a real powerhouse.
Great engines
pe reivers 03-20-2008 03:28 PM
Ditto that!
