RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA100 Mounting bolt pattern? (https://www.rcuniverse.com/forum/gas-engines-142/741158-da100-mounting-bolt-pattern.html)
PlaneKrazee 05-03-2003 01:21 PM
Does anyone know the bolt pattern for the DA100. Is it square and what are the dimensions center to center?
Brian
mglavin 05-03-2003 01:35 PM
70mm wide x 80mm high. The prop hub is centered within these dimensions.
PlaneKrazee 05-03-2003 01:42 PM
Thanks!
Thanks Mike.
Smokey 03-01-2004 10:50 PM
RE: Thanks!
Can someone please post a diagram of the mounting bolt pattern.
Smokey
