RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Ignition question (https://www.rcuniverse.com/forum/gas-engines-142/7497219-ignition-question.html)
Jordan18 05-14-2008 08:39 PM
Ignition question
1 Attachment(s)
I am about to buy a brison 3.2 that doesnt come with an ignition. I was curious as to how much that would cost to get a new one. any insight on this engine is appreciated.
rcbill 05-14-2008 08:53 PM
RE: Ignition question
I would call CH Ignitions and talk to them.... Bill
http://www.ch-ignitions.com
Jordan18 05-14-2008 08:54 PM
ok thanks for the help!
krayzc-RCU 05-14-2008 09:10 PM
1 Attachment(s)
what r u going to run it on? I ran mine on a DP Extra for many years, i parked the Extra to run the EF Yak. I am now off the peacekeepr and running a header and pipe. The clone ignition should save you a few bucks on the link that has been provided.
Jordan18 05-14-2008 09:16 PM
Hey,
It will be running in a Wild Hare Cap 232. I am pretty excited about it.
nedyob 05-14-2008 09:22 PM
I've got a Brison 3.2 in my WH Edge 540 28%, check Brison's web site for starting instructions, they helped out alot.
NEDYOB
Jordan18 05-14-2008 09:23 PM
Ok sounds like a plan!
krayzc-RCU 05-14-2008 10:16 PM
1 Attachment(s)
Yeah U R going to love a Cap. Is this your 1st gassers and also cap? If so make sure to fly your low rate elevator at no more than about 8-10 degrees of throw. I have had quite a few caps here is my lastest one that H-9 put back out. Hit us up if we can be of any assistance....[8D]
Jordan18 05-14-2008 11:07 PM
WOW! You guys are great! I couldn't ask for a nicer crowd.
Yes this will be my first gasser and my first CAP. I will be sure to make those adjustments.
I will be buying a whole new radio system and was wondering what a good set up would be without breaking the bank.
Tired Old Man 05-15-2008 12:14 AM
If I recall correctly the older blue anodized Brison 3.2 had a mechanical advance ignition. Most of the ignitions currently being marketed are auto advance. Not a problem but you would have to make a slight change to the timing ring to use an auto advance. The engine originally was equipped with a CH Ignition mechanical unit.
If I was making the choice for myself I would go with the original. I've always liked, and still like, the mechanical advance. Personally I believe them to run a bit smoother in all rpm ranges than the autos. Call Terry or Bill at CH and see what they have to say.
The engine itself is an extremely good product and will last forever while providing excellent power if you don't do straight down vertical landings. Needle settings to get it started for tuning are 1-1/2 open for both and adjust from there. 22-8 prop in a better brand will take you just about everywhere you want to go.
krayzc-RCU 05-15-2008 07:03 AM
Pat,
You are recalling correct. The orginal needle setting from the factory are
Low needle 1.5 - 2.5 out
High needle 5/8 - 1 out
Mine has been treated me well from the 1999-2000 era of buying it.
