Any idea which engine this is?
1 Attachment(s)
I bought this engine used and have no idea who made it. There are no manufacturer names on it and no displacement numbers. It is a reed valve engine and it has a B&B muffler. I tried to find some info on the B&B website with no luck. Please help if possible.
Thank you Sean |
RE: Any idea which engine this is?
brilelli.com ??
what does it weight 40 pounds. id suggest you not put that on anything. crrc 50 cc for $239.99 all day brand new.
Its either a Quadra 75 or up or its a Roper chainsaw engine.I cant remember who the company was but Hustler seems to come to mind or J&A.If i remember right they had needle bearings on the crank or at least some of them did.Do a search under those couple of names and see what comes up.TKG should chime in as i know he knows.Or pm him with a pic.
ORIGINAL: buck1856 Its either a Quadra 75 or up or its a Roper chainsaw engine.I cant remember who the company was but Hustler seems to come to mind or J&A.If i remember right they had needle bearings on the crank or at least some of them did.Do a search under those couple of names and see what comes up.TKG should chime in as i know he knows.Or pm him with a pic. |
Need input from Ralph C .................
| All times are GMT -8. The time now is 10:19 AM. |
