Replace the pin on DL50 piston possible?
1 Attachment(s)
I am in the process of getting a new ring in in my DL50 and found the pin is too short to prevent the ring from rotate. See the pictures attched.
My question is whether a longer pin can be put back. What is the method? Thanks |
RE: Replace the pin on DL50 piston possible?
The pin is to short even when the ring is on and compressed in the cylinder?
ORIGINAL: nonstoprc I am in the process of getting a new ring in in my DL50 and found the pin is too short to prevent the ring from rotate. See the pictures attched. My question is whether a longer pin can be put back. What is the method? Thanks Call Bob and DL USA, see if he has any in stock. While you have the piston out, I'd go ahead and clean up all the flow ports, too. |
ORIGINAL: Bob Pastorello ORIGINAL: nonstoprc I am in the process of getting a new ring in in my DL50 and found the pin is too short to prevent the ring from rotate. See the pictures attched. My question is whether a longer pin can be put back. What is the method? Thanks Call Bob and DL USA, see if he has any in stock. While you have the piston out, I'd go ahead and clean up all the flow ports, too. |
Talked to Bob at DLUSA and he did not carry the pin.
Ordered the piston and the ring and have them installed. Compression comes back right away. Nice! |
| All times are GMT -8. The time now is 09:27 AM. |
