RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   quadra 35 (https://www.rcuniverse.com/forum/gas-engines-142/774609-quadra-35-a.html)
SD_Daniel 05-15-2003 08:33 AM
quadra 35
I have a model kit that calls for a quadra 35 or similar motor. I hope someone can give me the stats on a quadra 35 so I could find a similar motor. I need the CC, HP, weight, RPM, etc...
Anyone please help!!!!
thanks
ANeat 05-15-2003 12:26 PM
Quadra specs
Hello; The Quadra or US engines 42 is pretty much the same motor as the 35. Fuji and Zenoah also make engines with similar specs. There are lots of other options with the newer/lighter/more powerful engines available today.
The Quadra 35 had about 2.5 hp and weighed 4 lbs.
Adam
Tiger 05-15-2003 02:17 PM
quadra 35
I have a Quadra 35 for sale if your interested. It's not new of course, but it runs fine. Looking for $150 OBO. Cheers!
Tiger
Dougboiler91 05-15-2003 04:20 PM
quadra 35
I recently installed a Quadra 35 in an 84 inch 16 lb airplane called a G-shark. Both were slightly used, and I was quite impressed with the Quadra 35. I'm turning a variable pitch 18*6*10 Zinger about 6800 rpms. It flies the G-Shark nicely, however vertical is not unlimited. A larger power-plant would cure this. But the point is that this is a good little motor pulling a 16 lb airframe. My Quadra was manufactured in 1979, and was like new when I got it.
Doug
