RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Optical Tachometer (https://www.rcuniverse.com/forum/gas-engines-142/7758937-optical-tachometer.html)
old git 07-22-2008 09:55 AM
Optical Tachometer
I've been looking at some adverts for Optical Tach's - Non Contact Tach's that have a mention of reflective strips.
Are these OK with model engines? Presumably one MUST be fitted to EACH blade to avoid imbalance?
Any comments please.
old git - - - - aka John L.
pe reivers 07-22-2008 02:33 PM
RE: Optical Tachometer
Most tachs we use are non-contact, and register light fluctuations. There is no need for reflective strips.
If the tach does need them, two strips are well balanced, but a single will do as well. You may get half or double rpm readings though, depending on the tach setup.
