Help identify this engine please.
1 Attachment(s)
I have an engine I need help identifying. The only marking is on flywheel which says Walbro G31
RE: Help identify this engine please.
Ryobi 31cc.Looks like a mount made from one of these 2 places.You could go check for sure.
carr-precision.com jagengines.com |
Almost certainly a Ryobi conversion and could be either 28 or 31cc.Many of these have been converted for model use and there are lots of parts/conversion suppliers and you can even buy an electronic ignition.
Converting them past using the stock flywheel (shaved) and ignition is less and less worth doing due to the low prices on Chinese gassers ex look at the latest from RC Showcase which come with stand offs,muffler,and variable timing ignition for less than it would cost to convert a Ryobi using a CH ignition unit. Ryobis are made in millions for cheap garden tools etc......... |
| All times are GMT -8. The time now is 04:31 PM. |
