Engine help
I have a 80" Midwset Extra 300
I am switching over to gas... on a budget. I am thinking a new XYZ 50(EI) $250, FTL52 (EI) $200, or a used US engines 43cc (Magneto) for about $100 less What thoughts does everyone have on these??? Thanks |
RE: Engine help
The magneto adds alot of weight, the way i look at it you get what you pay for, there are so many cheaper engines out there and many are also really nice and run well without breakdowns, even many of the cheaper engines also have the three crank bearings and that to me is a must and well worth it in the long run. Also look around as there are alot of nice engines out there different brands that are not real expensive and run well, look around for a second hand DA-50 you cannot go wrong with them engines, they have been out for years and is the best engine on the market today and has proven it over and over again, been in the winners circle now for many years as well, i bought the DA-50 and i would buy no other, but that is just me and i would not put down other engines, it is your choice and be happy with what you have.
RE: Engine help
I agree with Pilot 727, the DA-50 is a good & dependable engine. I put it in a 30% extra and have been pleased with its performance. I have 56 flights on it and never a glitch. It is pricey but look for a used one.
RE: Engine help
Get an engine with an electronic ignition (EI)...........Once you go gas you won't go back
RE: Engine help
The DL50 is gathering quite a following and there are several good reports about it's performance. You can do a search here and read what users have to say about it. An option that several people seem to shy away from but remains an excellent choice is to buy a second hand engine, and in your case a DA or equivalent might just fit the bill. Saves you the hassle of breaking-in or just for the hell of it you can fit a new ring and start over.
Karol |
RE: Engine help
I dont know bout that but them DA engines just keep on going and flying right past the shop, maybe in another ten years it may need a tune up or a knew plug.
RE: Engine help
Isn't a used DA 50 around $400.00?
That is a lot more than the $250 I was looking at. I fly approx 4-8 times a year. I wasn't looking to get the best, just something to throw in the Extra. I ordered a Perry pump for the Moki to see if that makes life better... Are the Chinese engines that bad? |
RE: Engine help
CRRC 50 will be fine,not balistic but plenty,there are good reports on them now,good luck!
RE: Engine help
I noticed here lately that the 50cc CRRC engines have been going for about $225 new on Ebay
RE: Engine help
I think _obbycity.com has a 45 & a 52cc engine for around $180 Take a look. Capt,n
| All times are GMT -8. The time now is 04:31 PM. |
