Spark Plug Data
Where can a person find all the data about spark plugs thread size and types of seat available. Also is ok to fill in a deep nick in a taper seat in the cyl head. Or is it best to re-machine the seat...and use a flat sealing washer? Thanks Capt,n[X(] P.S. What size is the threads on a CM6 spark plug?
RE: Spark Plug Data
Hello cj
This might help you. Spark plug decoding charts for NGK, Champ, Denso http://www.spark-plugs.co.uk/pages/t..._technical.htm For CM6: http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm That is: Thread 10mm , Hex 16 mm, Heat 6 For me its best to think in reverse when it comes to plugs. Measure first and then encode. Buying is the hard part :) Good luck /Munin |
RE: Spark Plug Data
Oh No!!! Internet Explorer cannot display this page???????? :eek::eek: Capt,n UPDATE.... Now the links are working....the next day. That is good data. Thanks again Capt,n;)
| All times are GMT -8. The time now is 04:31 AM. |
