RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G26 starting problem (https://www.rcuniverse.com/forum/gas-engines-142/7888414-g26-starting-problem.html)
borgie 08-26-2008 02:48 PM
i have had a g26 for about18 months ran well until this weekend it just would not start the 2000mah nmh battery flattened after 2 short flights so i recharged agann but still no luck on this engine as you all probably know there is a flashing red led which flashes once when igniton is turned on this led now stays permanently on on engine will not start does this mean ignition busted? any thoughts anyone
karolh 08-27-2008 09:18 PM
RE: G26 starting problem
Based on your location give Toni Clarke a call as he more than likely will be able to assist you in trouble shooting your problem.
Karol
