RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Drill bit diameter for DA Engines (https://www.rcuniverse.com/forum/gas-engines-142/8144637-drill-bit-diameter-da-engines.html)
Mark C 11-13-2008 07:14 PM
What size drill bit should you use to drill out the holes for the DA engines propellers.
nedyob 11-13-2008 07:27 PM
RE: Drill bit diameter for DA Engines
13/64 for the four retaining bolt holes.
NEDYOB
JoeAirPort 11-13-2008 07:31 PM
Same as the alum prop washer. It's not a precision fit, it's compression that holds the prop in place.
Mark C 11-13-2008 08:08 PM
