RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Gasoline engine storage (https://www.rcuniverse.com/forum/gas-engines-142/8294219-gasoline-engine-storage.html)
sdstick06 12-29-2008 11:21 AM
What should be done to a gas engine to store it over the winter months when it is not in use?
SRimer 12-29-2008 11:37 AM
RE: Gasoline engine storage
Nothing
Ram Jet 12-29-2008 12:46 PM
A fellow RCU member fills his crankcase with automatic tranmission fluid prior to storage. On my four cycles it will be easy as I will just unscrew the crankcase beather and inject it. My two cycles with get ATF dribbled into the transfer port and cylinder. I haven't tried it yet but will. Some guys use Marvel Mystery Oil but that's a mystery to me.
Bill
JoeAirPort 12-29-2008 01:22 PM
Run it every month or so. They get gunked up and/or dry when they are not run.
liquid_TR 12-29-2008 02:50 PM
Gas engines bearings dont get corroded if not used, even for a long time as the sticky oil and trapped gasoline vapour protects them.
But it'd be wise to run it every month for a couple of minutes, which is more than enough for upmost protection against ring sticking.
krayzc-RCU 12-29-2008 02:52 PM
it better start tne next time i need it when store my planes:D now I do baby my weed eater and lawnmower gas engines:)
sdstick06 12-29-2008 03:19 PM
Thanks guys
Tired Old Man 12-29-2008 03:54 PM
Run the carb dry and stick the engine in a plastic bag. GTG until next season. The bag is to keep the gas/exhaust odor down....
