Prop mounting pattern
Does the ZDZ 80 and 3W80Xi have the same prop bolt mounting pattern and prop shaft size.
RE: Prop mounting pattern
Same pattern but different bolt size, the 3W uses larger bolts. I've taken several props from my ZDZ80, and opened the bolt holes to the appropriate size for the 3W on another plane.
| All times are GMT -8. The time now is 12:45 PM. |
