RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   ENGINE OFFSET ?? (https://www.rcuniverse.com/forum/gas-engines-142/8439036-engine-offset.html)
skaha 02-04-2009 07:23 PM
ENGINE OFFSET ??
Hi guys, can anyone point me in the right direction? I am installing a 40cc gasser in a 98" Beaver on floats, what do you suggest for torque offset? The engine is bigger than required, but I will limit rpm and probably under prop it. I want the power margin to be able to fly it scale and as quiet as possible.
Terry
Tired Old Man 02-04-2009 08:11 PM
RE: ENGINE OFFSET ??
Center the prop shaft in the cowl. The kit likely already has right thrust built into the firewall. If you built it yourself and did not add right thrust to the firewall about 2 degrees will be just peachy.
the Wasp 02-04-2009 10:22 PM
you may need about 1 degree of down thrust, as my planes call for too
skaha 02-05-2009 01:53 AM
Thank you for the info, much appreciated.
