AMSOIL RECOMMENDATION CHART
I thought some of you guys would like to see this chart,, scroll down a bit,, http://www.synthetic-solutions.com/2cycle.htm Jim |
RE: AMSOIL RECOMMENDATION CHART
So we have the possibilty that we have a new Amsoil distributor? Regardless, there are a lot of oils out there better.
ORIGINAL: Tired Old Man Regardless, there are a lot of oils out there better. .........................Horsehocky ! |
""there are a lot of oils out there better""
Old Man please inform us (me), it wouldn't hurt to use a better oil ;) |
who's going to bring the beer and popcorn?
The problem with Amsoil is that the carbon formed is very hard and brown. It is very difficult to remove. In the UAV community where engines are run for hours, Amsoil lubed engines fail much quicker than other oils. This is especially true of the 80-100:1 mix of saber. The hobby flyer never works his engine much and so they don't notice the wear from Amsoil 100:1.
I did an oil/engine run test a few years back and if people are interested, I can repost the pictures. It shows amsoil's problems. For all of my work planes, I use Pennzoil air cooled which tested out as one of the better oils Elson |
Alternate choices would be Pennzoil Air Cooled, Bel Ray H1R and MC-1, Stihl Ultra, Redline, Motul 800, and a few others. WalMart oil at 32-1 is better than Amsoil over the long run. Moderate mix ratios are also key to obtaining the best performance out of your oil.
When **ALL** of us are dead and buried, if gas engines for RC are still in use, there will still be biased opinions based who knows what, and the debate of which is better, best, or worst, will still rage on.
I like Orville Reddenbacker Pour Over Oil Buttered popcorn the best..... |
Well, I try to run it at 100:1...;)
If nothing else at least your engines will smell good enough to eat. ;) :):D
Gotta add garlic first...
Here is the link to the pictures and oil test if people are interested
http://www.geistware.com/rcmodeling/...test/index.htm Elson |
| All times are GMT -8. The time now is 12:33 AM. |
