which engine
I'm looking at alternatives to power a Glens models 30% CAP
under consideration is : ZDZ 80 single 3W 75 single Stuart Mackays AW 75 does anyone have any experience of these engines ? how do they perform, start, what prop can they turn etc etc thanks Chris |
help
26-10 is your prop on all 3 desired engines.
Stay away from the 3w. The older ones with the resin cast reid valves are ok...the new plastic reid vlv's are weak and fail often Go with ZDZ...trust me. The other brand I have no exp. good luck... Both the ZDZ and the 3w hand start nicely. Both will kick back and hurt your hand. use glove. Start at idle. |
which engine
thanks, the ZDZ also seems to be the lightest in its class...
| All times are GMT -8. The time now is 03:00 PM. |
